fr8008怎么实现 SysTick ?
  • fr8008怎么实现 SysTick ?
  • 如下
     * INCLUDE FILES
    #include <stdio.h>
    #include <string.h>
    #include "gap_api.h"
    #include "gatt_api.h"
    #include "ble_stack.h"
    #include "app_config.h"
    #include "jump_table.h"
    #include "co_log.h"
    #include "plf.h"
    #include "driver_system.h"
    #include "driver_pmu.h"
    #include "driver_uart.h"
    #include "ble_simple_peripheral.h"
    #include "simple_gatt_service.h"
    #undef LOG_LOCAL_LEVEL
    #define LOG_LOCAL_LEVEL        (LOG_LEVEL_INFO)
    const char *app_tag = "project";
    #define SYSTEM_STACK_SIZE           0x800
    void patch_init(void);
    void disable_ch_sel_2(void);
    void conn_req_rssi_filter(int8_t rssi_value);
    void systick_init(void);
    void systick_delay_ms(uint32_t ms);
    void systick_delay_us(uint32_t us);
    uint32_t systick_get_ms(void);
     * LOCAL VARIABLES
    static volatile uint32_t g_systick_ms = 0;
    __attribute__((section("stack_section"))) static uint32_t system_stack[SYSTEM_STACK_SIZE/sizeof(uint32_t)];
    const struct jump_table_version_t _jump_table_version __attribute__((section("jump_table_3"))) =
        .stack_top_address = &system_stack[SYSTEM_STACK_SIZE/sizeof(uint32_t)],
        .firmware_version = 0x00000000,
    const struct jump_table_image_t _jump_table_image __attribute__((section("jump_table_1"))) =
        .image_type = IMAGE_TYPE_APP,
        .image_size = 0x20000,
     * @fn      SysTick_Handler
     * @brief   1ms tick. Overrides the WEAK handler in boot_vectors.
    void SysTick_Handler(void)
        g_systick_ms++;
     * @fn      systick_init
     * @brief   Start SysTick at 1ms. Must be called after system_set_clock().
        uint32_t ticks = system_get_clock() / 1000;
        if ((ticks == 0) || ((ticks - 1) > SysTick_LOAD_RELOAD_Msk)) {
            return;
        SysTick_Config(ticks);
     * @fn      systick_get_ms
     * @brief   Milliseconds since systick_init. Does not advance in sleep.
        return g_systick_ms;
     * @fn      systick_delay_ms
     * @brief   Blocking delay. Do not call with interrupts disabled.
        uint32_t start = g_systick_ms;
        while ((uint32_t)(g_systick_ms - start) < ms) {
     * @fn      systick_delay_us
     * @brief   Blocking us delay. Temporarily uses SysTick as a one-shot,
     *          then restores the 1ms tick.
        uint32_t clk = system_get_clock();
        uint32_t ticks_per_us;
        uint32_t max_us;
        if ((us == 0) || (clk < 1000000)) {
            return;
        ticks_per_us = clk / 1000000;
        max_us = SysTick_LOAD_RELOAD_Msk / ticks_per_us;
        while (us) {
            uint32_t chunk = (us > max_us) ? max_us : us;
            SysTick->CTRL = 0;
            SysTick->LOAD = ticks_per_us * chunk - 1;
            SysTick->VAL  = 0;
            SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk | SysTick_CTRL_ENABLE_Msk;
            while ((SysTick->CTRL & SysTick_CTRL_COUNTFLAG_Msk) == 0) {
            us -= chunk;
        systick_init();
     * @fn      user_entry_before_sleep_imp
     * @brief   Before system goes to sleep mode, user_entry_before_sleep_imp()
     *          will be called, MCU peripherals can be configured properly before
     *          system goes to sleep, for example, some MCU peripherals need to be
     *          used during the system is in sleep mode.
     * @param   None.
     * @return  None.
    __attribute__((section("ram_code"))) void user_entry_before_sleep_imp(void)
        /* SysTick uses CPU clock and would wake the core every 1ms */
        SysTick->CTRL = 0;
        pmu_calibration_stop();
        uart_putc_noint_no_wait(UART0, 's');
        co_delay_100us(1);
    	pmu_set_pin_to_PMU(GPIO_PORT_A, (1<<GPIO_BIT_1));
    	pmu_set_pin_to_PMU(GPIO_PORT_A, (1<<GPIO_BIT_0)|(1<<GPIO_BIT_4));
    	pmu_set_pin_dir(GPIO_PORT_A, (1<<GPIO_BIT_0)|(1<<GPIO_BIT_4),GPIO_DIR_IN);
    	pmu_set_pin_pull(GPIO_PORT_A, (1<<GPIO_BIT_0)|(1<<GPIO_BIT_4),GPIO_PULL_NONE);
        pmu_oscap_set(0);
     * @fn      user_entry_after_sleep_imp
     * @brief   After system wakes up from sleep mode, user_entry_after_sleep_imp()
     *          will be called, MCU peripherals need to be initialized again,
     *          this can be done in user_entry_after_sleep_imp(). MCU peripherals
     *          status will not be kept during the sleep.
     * @param   None.
     * @return  None.
    __attribute__((section("ram_code"))) void user_entry_after_sleep_imp(void)
        pmu_set_pin_to_CPU(GPIO_PORT_A, (1<<GPIO_BIT_0));
        system_set_port_mux(GPIO_PORT_A, GPIO_BIT_0, PORTA0_FUNC_UART0_RXD);
        system_set_port_mux(GPIO_PORT_A, GPIO_BIT_1, PORTA1_FUNC_UART0_TXD);
        uart_init(UART0, 1152);
        fr_uart_enableIrq(UART0, Uart_irq_erbfi);
        /* RC calibration start. Ensure the accuracy of sleep wake time */
        pmu_calibration_start(PMU_CALI_SEL_RCLFOSC, LP_RC_CALIB_CNT);
        uart_putc_noint_no_wait(UART0, 'w');
        co_delay_100us(1);
        NVIC_EnableIRQ(PMU_IRQn);
        systick_init();
    __attribute__((section("ram_code"))) void main_loop(void)
        while(1)
            if(ble_stack_schedule_allow())
                /*user code should be add here*/
                /* schedule internal stack event */
                ble_stack_schedule();
            GLOBAL_INT_DISABLE();
            switch(ble_stack_sleep_check())
                case 2:
                    ble_stack_enter_sleep();
                break;
                default:
                    break;
            GLOBAL_INT_RESTORE();
            ble_stack_schedule_backward();
     * @fn      proj_init
     * @brief   Main entrancy of user application. This function is called after BLE stack
     *          is initialized, and all the application code will be executed from here.
     *          In that case, application layer initializtion can be startd here.
     * @param   None.
     * @return  None.
    void proj_init(void)
        LOG_INFO(app_tag, "BLE Peripheral\r\n");
    	co_printf("%s\r\n",__func__);
        systick_delay_ms(500);
    	co_printf("%s\r\n",__TIME__);
        // Application layer initialization, can included bond manager init,
        // advertising parameters init, scanning parameter init, GATT service adding, etc.
        simple_peripheral_init();
  • @mars 休眠后, 它是不是就会 停止中断, 或者是休眠前,需要代码给先停止中断呢?如果是,则停止的代码是什么呢?谢谢
  • Global Moderator
    @黄书剑
    休眠后会自动停止
    休眠所有外设会掉电
