为什么FR8008GPU用不了QSPI的四线psram,只能用单线读取
#include <stdint.h>
#include <stdbool.h>#include "plf.h"
#include "driver_system.h"
#include "driver_psram.h"#include "co_log.h"
#include "co_printf.h"
#include "driver_gpio.h"
#include "sys_utils.h"
#include "bsp_psram.h"#undef LOG_LOCAL_LEVEL
#define LOG_LOCAL_LEVEL (LOG_LEVEL_INFO)
static const char *psram_tag = "psram";#define PSRAM_BASE QSPI1_DAC_ADDRESS
extern void psram_reset(void);
extern void psram_set_delay(uint8_t d);
extern void psram_set_ahb_trigger(uint32_t addr);
extern void psram_set_frame(uint8_t r_op, uint8_t r_it, uint8_t r_at, uint8_t r_dt, uint8_t r_dummy,
uint8_t w_op, uint8_t w_at, uint8_t w_dt, uint8_t w_dummy);static void psram_pins_qspi0(void)
system_set_port_mux(GPIO_PORT_C, GPIO_BIT_0, PORTC0_FUNC_QSPI0_IO3);
system_set_port_mux(GPIO_PORT_C, GPIO_BIT_1, PORTC1_FUNC_QSPI0_SCLK0);
system_set_port_mux(GPIO_PORT_C, GPIO_BIT_2, PORTC2_FUNC_QSPI0_CSN0);
system_set_port_mux(GPIO_PORT_C, GPIO_BIT_3, PORTC3_FUNC_QSPI0_IO1);
system_set_port_mux(GPIO_PORT_C, GPIO_BIT_4, PORTC4_FUNC_QSPI0_IO2);
system_set_port_mux(GPIO_PORT_C, GPIO_BIT_5, PORTC5_FUNC_QSPI0_IO0);
}static void psram_lines_gpio_check(void)
GPIO_InitTypeDef io;
__SYSTEM_GPIO_CLK_ENABLE();LOG_INFO(psram_tag, "line check: PORTC mux=%08x", system_regs->port_mux[2]); for (uint8_t pin = 0; pin < 6; pin++) { system_set_port_mux(GPIO_PORT_C, pin, PORT_FUNC_GPIO); io.Mode = GPIO_MODE_INPUT; io.Pull = GPIO_PULLUP; io.Pin = (GPIO_PIN_0 << pin); gpio_init(GPIO_C, &io); co_delay_100us(1); uint8_t up = gpio_read_pin(GPIO_C, (GPIO_PIN_0 << pin)) ? 1 : 0; io.Pull = GPIO_PULLDOWN; gpio_init(GPIO_C, &io); co_delay_100us(1); uint8_t dn = gpio_read_pin(GPIO_C, (GPIO_PIN_0 << pin)) ? 1 : 0; co_printf("psram line PC%d: pullup=%d pulldown=%d %s\r\n", pin, up, dn, (up == 1 && dn == 0) ? "ok" : "!!"); } io.Mode = GPIO_MODE_INPUT; io.Pin = GPIO_PIN_2; io.Pull = GPIO_PULLUP; gpio_init(GPIO_D, &io); uint8_t cup = gpio_read_pin(GPIO_D, GPIO_PIN_2) ? 1 : 0; io.Pull = GPIO_PULLDOWN; gpio_init(GPIO_D, &io); uint8_t cdn = gpio_read_pin(GPIO_D, GPIO_PIN_2) ? 1 : 0; co_printf("psram ctrl PD2: pullup=%d pulldown=%d\r\n", cup, cdn);}
bool bsp_psram_init(void)
co_delay_100us(500);psram_lines_gpio_check(); __SYSTEM_GPIO_CLK_ENABLE(); /* 参考例程(lvgl_knob_open_demo)同款参考时钟配置 */ system_regs->mdm_qspi_cfg.qspi_ref_128m_en = 1; system_regs->mdm_qspi_cfg.qspi_ref_clk_sel = 1; system_set_internal_flash_clock_div(1); psram_pins_qspi0(); (void)psram_init(PSRAM_CLK_SEL_COREH_96M); system_regs->mdm_qspi_cfg.qspi0_ref_clk_en = 1; system_regs->mdm_qspi_cfg.qspi0_hclk_en = 1; psram_set_ahb_trigger(PSRAM_BASE); volatile uint8_t *img = (volatile uint8_t *)PSRAM_BASE; for (int attempt = 0; attempt < 3; attempt++) { psram_reset(); co_delay_100us(10); psram_set_frame(0x03, 0, 0, 0, 0, 0x02, 0, 0, 0); img[0] = 0x5Au; img[1] = 0xA5u; co_delay_100us(1); for (int d = 0; d < 16; d++) { psram_set_delay((uint8_t)d); co_delay_100us(1); if (img[0] == 0x5Au && img[1] == 0xA5u) { psram_set_delay((uint8_t)d); LOG_INFO(psram_tag, "psram ready (spi, delay tap %d)", d); return true; } } LOG_INFO(psram_tag, "spi scan fail attempt %d, retry", attempt); } LOG_INFO(psram_tag, "psram init FAIL (spi x3)"); return false;}
#include <stdint.h>
#include <string.h>#include "plf.h"
#include "driver_qspi.h"
#include "driver_pmu.h"
#include "driver_cache.h"#include "co_printf.h"
#include "sys_utils.h"#ifdef INLINE
#undef INLINE
#endif
#define INLINE#define PSRAM_ENABLE_Q_MODE 1 /* TEST: all-quad framing at slow clock */
#define PSRAM_CLK_DIV_SEL QSPI_BAUDRATE_DIV_2
#define PSRAM_BASE QSPI1_DAC_ADDRESS#define PSRAM_READ_IDENTIFICATION 0x9F
#define PSRAM_READ_OPCODE 0x03
#define PSRAM_FAST_READ_OPCODE 0x0B
#define PSRAM_FAST_QUAL_READ_OPCODE 0xEB#define PSRAM_PAGE_PROGRAM_OPCODE 0x02
#define PSRAM_PAGE_QUAL_PROGRAM_OPCODE 0x38#define PSRAM_ENTER_QUAD_MODE_OPCODE 0x35
#define PSRAM_EXIT_QUAD_MODE_OPCODE 0xF5#define PSRAM_RESET_ENABLE_OPCODE 0x66
#define PSRAM_RESET_OPCODE 0x99#define QSPI0_STIG_MAX_SINGLE_LEN 8
#define QSPI0_STIG_BANK_DEPTH 128#define QSPI0_HIGH_SPEED 1
uint8_t psram_delay = 0xFF;
static const struct qspi_stig_reg_t psram_read_id_cmd = {
.enable_bank = 0,
.dummy_cycles = 0,
.write_bytes = 0,
.enable_write = 0,
.addr_bytes = 0,
.enable_mode = 0,
.enable_cmd_addr = 0,
.read_bytes = 3,
.enable_read = 1,
.opcode = PSRAM_READ_IDENTIFICATION,
};static const struct qspi_stig_reg_t enter_quad_mode_cmd = {
.enable_bank = 0,
.dummy_cycles = 0,
.write_bytes = 0,
.enable_write = 0,
.addr_bytes = 0,
.enable_mode = 0,
.read_bytes = 0,
.enable_read = 0,
.opcode = PSRAM_ENTER_QUAD_MODE_OPCODE,
};static const struct qspi_stig_reg_t reset_enable_cmd = {
.enable_bank = 0,
.dummy_cycles = 0,
.write_bytes = 0,
.enable_write = 0,
.addr_bytes = 0,
.enable_mode = 0,
.read_bytes = 0,
.enable_read = 0,
.opcode = PSRAM_RESET_ENABLE_OPCODE,
};static const struct qspi_stig_reg_t reset_cmd = {
.enable_bank = 0,
.dummy_cycles = 0,
.write_bytes = 0,
.enable_write = 0,
.addr_bytes = 0,
.enable_mode = 0,
.read_bytes = 0,
.enable_read = 0,
.opcode = PSRAM_RESET_OPCODE,
};//static const struct qspi_stig_reg_t exit_quad_mode_cmd = {
// .enable_bank = 0,
// .dummy_cycles = 0,
// .write_bytes = 0,
// .enable_write = 0,
// .addr_bytes = 0,
// .enable_mode = 0,
// .enable_cmd_addr = 0,
// .read_bytes = 0,
// .enable_read = 0,
// .opcode = PSRAM_EXIT_QUAD_MODE_OPCODE,
//};volatile struct qspi_regs_t *qspi0_ctrl = (volatile struct qspi_regs_t *)QSPI0_APB_BASE;
INLINE void qspi0_cfg_set_enable(uint8_t en)
qspi0_ctrl->config.enable = en;
}INLINE void qspi0_cfg_set_cpol(uint8_t high)
qspi0_ctrl->config.cpol = high;
}INLINE void qspi0_cfg_set_cpha(uint8_t rising)
qspi0_ctrl->config.cpha = rising;
}INLINE void qspi0_cfg_set_hold(uint8_t hold)
qspi0_ctrl->config.hold_pin = hold;
}INLINE void qspi0_cfg_set_reset(uint8_t reset)
qspi0_ctrl->config.reset_pin = reset;
}INLINE void qspi0_cfg_set_reset_sel(uint8_t dedicated)
qspi0_ctrl->config.reset_pin_conf = dedicated;
}INLINE void qspi0_cfg_set_enable_dac(uint8_t en)
qspi0_ctrl->config.enable_DAC = en;
}INLINE void qspi0_cfg_set_enable_legacy(uint8_t en)
qspi0_ctrl->config.enable_legacy = en;
}INLINE void qspi0_cfg_set_write_protect(uint8_t wp)
qspi0_ctrl->config.write_en_pin = wp;
}INLINE void qspi0_cfg_set_enable_remap(uint8_t en)
qspi0_ctrl->config.enable_AHB_remap = en;
}static void qspi0_cfg_set_baudrate(uint8_t baudrate);
INLINE void qspi0_cfg_set_enable_AHB_decoder(uint8_t en)
qspi0_ctrl->config.enable_AHB_decoder = en;
}INLINE int qspi0_is_busy(void)
return (qspi0_ctrl->config.status == 0);
}INLINE void qspi0_read_set_opcode(uint8_t opcode)
qspi0_ctrl->read_conf.opcode_no_XIP = opcode;
}INLINE void qspi0_read_set_instruction_type(uint8_t type)
qspi0_ctrl->read_conf.instruction_type = type;
}INLINE void qspi0_read_set_address_type(uint8_t type)
qspi0_ctrl->read_conf.addr_type = type;
}INLINE void qspi0_read_set_data_type(uint8_t type)
qspi0_ctrl->read_conf.data_type = type;
}INLINE void qspi0_read_set_mode_en(uint8_t en)
qspi0_ctrl->read_conf.enable_mode = en;
}INLINE void qspi0_read_set_dummy_cycles(uint8_t cycles)
qspi0_ctrl->read_conf.dummy_cycles = cycles;
}INLINE void qspi0_write_set_opcode(uint8_t opcode)
qspi0_ctrl->write_conf.opcode = opcode;
}INLINE void qspi0_write_set_wel_dis(uint8_t disable)
qspi0_ctrl->write_conf.disable_WEL = disable;
}INLINE void qspi0_write_set_address_type(uint8_t type)
qspi0_ctrl->write_conf.addr_type = type;
}INLINE void qspi0_write_set_data_type(uint8_t type)
qspi0_ctrl->write_conf.data_type = type;
}INLINE void qspi0_write_set_dummy_cycles(uint8_t cycles)
qspi0_ctrl->write_conf.dummy_cycles = cycles;
}INLINE void qspi0_set_remap_address(uint32_t address)
qspi0_ctrl->remap_address = address;
}INLINE void qspi0_set_mode_bit(uint8_t mode)
qspi0_ctrl->mode_bits = (uint32_t)mode;
}INLINE void qspi0_poll_set_opcode(uint8_t opcode)
qspi0_ctrl->poll_cfg.opcode_poll = opcode;
}INLINE void qspi0_poll_set_bit_index(uint8_t index)
qspi0_ctrl->poll_cfg.poll_bit_index = index;
}INLINE void qspi0_poll_set_polarity(uint8_t pol)
qspi0_ctrl->poll_cfg.poll_polarity = pol;
}INLINE void qspi0_poll_set_disable(uint8_t dis)
qspi0_ctrl->poll_cfg.disable_poll = dis;
}INLINE void qspi0_poll_set_expire(uint8_t en, uint32_t duration)
qspi0_ctrl->poll_cfg.enable_expiration = en;
if(en) {
qspi0_ctrl->poll_expiration = duration;
}INLINE void qspi0_poll_set_poll_count(uint8_t count)
qspi0_ctrl->poll_cfg.poll_count = count;
}INLINE void qspi0_poll_set_poll_delay(uint8_t delay)
qspi0_ctrl->poll_cfg.poll_repetition_delay = delay;
}INLINE void qspi0_set_cmd_addr(uint32_t addr)
qspi0_ctrl->cmd_address = addr;
}INLINE void qspi0_stig_set_opcode(uint8_t opcode)
qspi0_ctrl->cmd_ctrl.opcode = opcode;
}INLINE void qspi0_stig_set_read_en(uint8_t en)
qspi0_ctrl->cmd_ctrl.enable_read = en;
}INLINE void qspi0_stig_set_read_bytes(uint8_t bytes)
qspi0_ctrl->cmd_ctrl.read_bytes = bytes;
}INLINE void qspi0_stig_set_addr(uint8_t en, uint8_t bytes, uint32_t addr)
qspi0_ctrl->cmd_ctrl.enable_cmd_addr = en;
qspi0_ctrl->cmd_ctrl.addr_bytes = bytes;
if(en) {
}INLINE void qspi0_stig_set_mode_en(uint8_t en)
qspi0_ctrl->cmd_ctrl.enable_mode = en;
}INLINE void qspi0_stig_set_write_en(uint8_t en)
qspi0_ctrl->cmd_ctrl.enable_write = en;
}INLINE void qspi0_stig_set_write_bytes(uint8_t bytes)
qspi0_ctrl->cmd_ctrl.write_bytes = bytes;
}INLINE void qspi0_stig_set_dummy_cycles(uint8_t cycles)
qspi0_ctrl->cmd_ctrl.dummy_cycles = cycles;
}INLINE void qspi0_stig_set_mem_bank(uint8_t en, uint8_t bytes)
qspi0_ctrl->cmd_ctrl.enable_bank = en;
if(en) {
qspi0_ctrl->cmd_ctrl_mem.mem_bank_req_bytes = bytes;
qspi0_ctrl->config.baud_rate = baudrate;
}static const struct qspi_stig_reg_t psram_stig_read_cmd = {
.enable_bank = 0,
.dummy_cycles = 0,
.write_bytes = 0,
.enable_write = 0,
.addr_bytes = 2, /* QSPI_STIG_ADDR_BYTES_3 /
.enable_mode = 0,
.enable_cmd_addr = 1,
.read_bytes = 3,
.enable_read = 1,
.opcode = PSRAM_READ_OPCODE, / 0x03 */
};static const struct qspi_stig_reg_t psram_stig_write_cmd = {
.enable_bank = 0,
.dummy_cycles = 0,
.write_bytes = 3,
.enable_write = 1,
.enable_mode = 0,
.read_bytes = 0,
.enable_read = 0,
.opcode = PSRAM_PAGE_PROGRAM_OPCODE, / 0x02 */
};static int qspi0_stig_cmd(struct qspi_stig_reg_t cmd, enum qspi_stig_cmd_type_t type, int len, uint8_t *buffer)
uint32_t tmp_u32[2];
uint8_t *tmp_u8 = (uint8_t *)tmp_u32;if(type == QSPI_STIG_CMD_BANK_READ) { if(QSPI0_STIG_BANK_DEPTH < len) { return -1; } } else { if(QSPI0_STIG_MAX_SINGLE_LEN < len) { return -1; } } while(qspi0_is_busy()); if(type == QSPI_STIG_CMD_EXE) { qspi0_ctrl->cmd_ctrl = cmd; qspi0_ctrl->cmd_ctrl.execute = 1; while(qspi0_ctrl->cmd_ctrl.progress_status); } else { if(type == QSPI_STIG_CMD_WRITE) { memcpy(tmp_u8, buffer, len); qspi0_ctrl->write_data_L = tmp_u32[0]; qspi0_ctrl->write_data_H = tmp_u32[1]; cmd.write_bytes = len - 1; qspi0_ctrl->cmd_ctrl = cmd; qspi0_ctrl->cmd_ctrl.execute = 1; while(qspi0_ctrl->cmd_ctrl.progress_status); } else { cmd.read_bytes = len - 1; qspi0_ctrl->cmd_ctrl = cmd; qspi0_ctrl->cmd_ctrl.execute = 1; while(qspi0_ctrl->cmd_ctrl.progress_status); if(type == QSPI_STIG_CMD_READ) { tmp_u32[0] = qspi0_ctrl->read_data_L; tmp_u32[1] = qspi0_ctrl->read_data_H; //co_printf("READ_L: 0x%08x, READ_H: 0x%08x.\r\n", tmp_u32[0], tmp_u32[1]); memcpy(buffer, tmp_u8, len); } else { //TBD, BANK READ } } } return 0;}
void psram_enter_quad(void)
qspi0_stig_cmd(enter_quad_mode_cmd, QSPI_STIG_CMD_EXE, 0, NULL);
}uint32_t psram_read_id(void)
uint32_t flash_id;
qspi0_stig_cmd(psram_read_id_cmd, QSPI_STIG_CMD_READ, 3, (uint8_t *)&flash_id);
return (flash_id&0xffffff);
}static void psram_controller_init(uint16_t page_boundary)
while(qspi0_is_busy());#if PSRAM_ENABLE_Q_MODE == 1
qspi0_read_set_opcode(PSRAM_FAST_READ_OPCODE);
qspi0_read_set_instruction_type(QSPI_WIRE_TYPE_QIO);
qspi0_read_set_address_type(QSPI_WIRE_TYPE_QIO);
qspi0_read_set_data_type(QSPI_WIRE_TYPE_QIO);
qspi0_read_set_dummy_cycles(4);
qspi0_read_set_mode_en(0);
qspi0_set_mode_bit(0);//8 bits data after addrqspi0_write_set_opcode(PSRAM_PAGE_QUAL_PROGRAM_OPCODE); qspi0_write_set_address_type(QSPI_WIRE_TYPE_QIO); qspi0_write_set_data_type(QSPI_WIRE_TYPE_QIO); qspi0_write_set_dummy_cycles(0);#else
qspi0_read_set_opcode(PSRAM_FAST_QUAL_READ_OPCODE);
qspi0_read_set_instruction_type(QSPI_WIRE_TYPE_STAND);
qspi0_read_set_dummy_cycles(6);
qspi0_set_mode_bit(0);//8 bits data after addrqspi0_write_set_opcode(PSRAM_PAGE_QUAL_PROGRAM_OPCODE); qspi0_write_set_address_type(QSPI_WIRE_TYPE_QIO); qspi0_write_set_data_type(QSPI_WIRE_TYPE_QIO); qspi0_write_set_dummy_cycles(0);#endif
//init configuration register qspi0_cfg_set_cpol(0); qspi0_cfg_set_cpha(0); qspi0_cfg_set_enable_dac(1); qspi0_cfg_set_enable_legacy(0); qspi0_cfg_set_enable_remap(1);#if QSPI0_HIGH_SPEED
qspi0_cfg_set_baudrate(PSRAM_CLK_DIV_SEL);
#else
qspi0_cfg_set_baudrate(QSPI_BAUDRATE_DIV_32);
#endif
qspi0_cfg_set_enable_AHB_decoder(1);
qspi0_write_set_wel_dis(1);
qspi0_poll_set_disable(1);#if QSPI0_HIGH_SPEED
qspi0_ctrl->read_cap.delay_capture = 3;
#else
qspi0_ctrl->read_cap.delay_capture = 0;
#endif
qspi0_ctrl->read_cap.enable_loopback_clk = 1;
qspi0_ctrl->delay.sel_start_offset = 2;
qspi0_ctrl->delay.sel_end_offset = 2;
qspi0_ctrl->delay.sel_dessert = 2;
qspi0_ctrl->cs_ctrl.rd_brk_en = 1;
qspi0_ctrl->cs_ctrl.disable_cs_after_first_byte = 0; /* forum-verified working value for quad PSRAM (was 1 in SDK) /
qspi0_ctrl->cs_ctrl.page_boundary_protect_en = 1;
qspi0_ctrl->cs_ctrl.page_boundary = page_boundary;
qspi0_set_remap_address(QSPI1_DAC_ADDRESS);
qspi0_ctrl->AHB_trigger_address = PSRAM_BASE; / DAC window trigger (old project set it; default points elsewhere) */
qspi0_cfg_set_enable(1);
}void psram_cache_enable(void)
__CACHE_FLUSH(CACHE);
__CACHE_WR_MODE_SET(CACHE, CACHE_WR_WRITE_THROUGH);
__CACHE_ADDR_RANGEx_BANK_SET(CACHE, 0, 0x0000);
__CACHE_ADDR_RANGEx_MASK_SET(CACHE, 0, 0x0000);
__CACHE_ADDR_RANGEx_POL_SET(CACHE, 0, CACHE_POL_CACHABLE);
__CACHE_ADDR_RANGEx_ENABLE(CACHE, 0);
__CACHE_ENABLE(CACHE);
}bool psram_init(enum psram_clk_sel_t clk_sel)
uint32_t ref_clk;if (clk_sel >= PSRAM_CLK_SEL_MAX) { return false; } switch (clk_sel) { case PSRAM_CLK_SEL_COREH_48M: system_regs->mdm_qspi_cfg.qspi0_ref_clk_sel = 0; ref_clk = 48000000; break; case PSRAM_CLK_SEL_COREH_96M: system_regs->mdm_qspi_cfg.qspi0_ref_clk_sel = 1; ref_clk = 96000000; break; case PSRAM_CLK_SEL_COREH_192M: system_regs->mdm_qspi_cfg.qspi0_ref_clk_sel = 2; ref_clk = 192000000; break; default: return false; } system_regs->mdm_qspi_cfg.qspi0_ref_clk_en=1; system_regs->mdm_qspi_cfg.qspi0_hclk_en=1; system_regs->mdm_qspi_cfg.qspi0_io_ctl_oen=0; if(psram_delay == 0xFF) { qspi0_stig_cmd(reset_enable_cmd, QSPI_STIG_CMD_EXE, 0, NULL); qspi0_stig_cmd(reset_cmd, QSPI_STIG_CMD_EXE, 0, NULL); co_delay_10us(20); /* 200us reset recovery before quad entry */ /* serial write magic @0 while die in SPI mode (baseline) */ { uint32_t magic = 0xc3c3c3c3; uint32_t chk = 0; qspi0_ctrl->cmd_address = 0; qspi0_stig_cmd(psram_stig_write_cmd, QSPI_STIG_CMD_WRITE, 4, (uint8_t *)&magic); qspi0_ctrl->cmd_address = 0; qspi0_stig_cmd(psram_stig_read_cmd, QSPI_STIG_CMD_READ, 4, (uint8_t *)&chk); co_printf("psram serial w/r chk=%x\r\n", chk); }#if PSRAM_ENABLE_Q_MODE == 1
psram_enter_quad();
#endif // PSRAM_ENABLE_Q_MODE == 1
}/* about 100 bytes can be transmitted during 8us when QSPI clock is 24MHz */ ref_clk /= ((PSRAM_CLK_DIV_SEL+1) * 2); uint32_t bytes = ref_clk / 240000; uint32_t boundary_cfg = 1 << (31 - __CLZ(bytes)); if (boundary_cfg >= 0x100) { boundary_cfg = 0x100; } psram_controller_init(boundary_cfg); if(psram_delay != 0xFF) { qspi0_ctrl->read_cap.delay_capture = psram_delay; } else { /* detect read capture delay configuration */ uint8_t delay_lower, delay_upper, index; /* QUAD READ test v2: sweep dummy cycles x capture taps. Serial-written c3c3c3c3 @0 must appear via quad DAC read. Log non-zero only. */ { static const uint8_t dummies[] = {4, 2, 6, 8, 0, 3, 5, 1, 7}; uint8_t found = 0; for (uint8_t di = 0; di < sizeof(dummies) && !found; di++) { qspi0_read_set_dummy_cycles(dummies[di]); for (index = 0; index < 16; index++) { while(qspi0_is_busy()); qspi0_ctrl->read_cap.delay_capture = index; uint32_t dbg = *(volatile uint32_t *)(PSRAM_BASE); if (dbg != 0) { co_printf("psram qt(d=%d,t=%d)=%x\r\n", dummies[di], index, dbg); } if (dbg == 0xc3c3c3c3) { co_printf("psram QUAD READ OK (dummy=%d tap=%d)\r\n", dummies[di], index); found = 1; break; } } } if (!found) { co_printf("psram QUAD READ DEAD (9 dummies x 16 taps)\r\n"); } } /* QUAD WRITE test: write via quad DAC @4, verify via SERIAL read @4 */ { *(volatile uint32_t *)(PSRAM_BASE + 4) = 0x5a5a5a5a; while(qspi0_is_busy()); uint32_t chk4 = 0; qspi0_ctrl->cmd_address = 4; qspi0_stig_cmd(psram_stig_read_cmd, QSPI_STIG_CMD_READ, 4, (uint8_t *)&chk4); co_printf("psram quad w @4, serial sees=%x %s\r\n", chk4, (chk4 == 0x5a5a5a5a) ? "QUAD WRITE OK" : "QUAD WRITE DEAD"); } *(volatile uint32_t *)(PSRAM_BASE) = 0x5a5a5a5a; while(qspi0_is_busy()); for (index = 0; index < 16; index++) { while(qspi0_is_busy()); qspi0_ctrl->read_cap.delay_capture = index; if (*(volatile uint32_t *)(PSRAM_BASE) == 0x5a5a5a5a) { break; } } if (index == 16) { system_regs->mdm_qspi_cfg.qspi0_ref_clk_en=0; return false; } else { delay_lower = index; } for (; index < 16; index++) { while(qspi0_is_busy()); qspi0_ctrl->read_cap.delay_capture = index; delay_upper = index; if (*(volatile uint32_t *)(PSRAM_BASE) != 0x5a5a5a5a) { break; } } psram_delay = ((delay_lower + delay_upper)>>1); while(qspi0_is_busy()); qspi0_ctrl->read_cap.delay_capture = psram_delay; } return true;}
/* ---- old-project helpers restored: the only PSRAM path proven on this
board+die (single-lane DAC, verified working on FR8008GPU 2026-10-27). -
SDK quad framings (all-quad and 1-4-4) both fail on this die. ---- */
}void psram_set_delay(uint8_t d)
qspi0_ctrl->read_cap.delay_capture = d;
}void psram_set_ahb_trigger(uint32_t addr)
qspi0_ctrl->AHB_trigger_address = addr;
}void psram_set_frame(uint8_t r_op, uint8_t r_it, uint8_t r_at, uint8_t r_dt, uint8_t r_dummy,
qspi0_read_set_opcode(r_op);
qspi0_read_set_instruction_type(r_it);
qspi0_read_set_address_type(r_at);
qspi0_read_set_data_type(r_dt);
qspi0_read_set_dummy_cycles(r_dummy);
qspi0_write_set_opcode(w_op);
qspi0_write_set_address_type(w_at);
qspi0_write_set_data_type(w_dt);
qspi0_write_set_dummy_cycles(w_dummy);
