FR801x系列芯片Flash添加写保护方法
问题描述:
FR801x系列芯片在使用过程中,由于断电不彻底(断电后VBAT电压没有到0V)、断电到上电时间小于10ms,导致芯片Flash可能会被异常修改的问题。问题解决方式:
1、 建议在烧写时,烧写工具勾选“写保护”,该操作对程序所对应Flash区域进行写保护操作,
烧写工具:
链接:https://pan.baidu.com/s/1fAaTMjRb-HQ1mT3QItd1_w
提取码:1p3y2、对整片Flash进行写保护操作,参考如下代码:
#define FLASH_WRITE_DISABLE_OPCODE 0x04
#define FLASH_WRITE_ENABLE_OPCODE 0x06
#define FLASH_WRITE_STATUS_REG_OPCODE 0x01
#define FLASH_READ_STATUS_REG_OPCODE 0x05static void flash_write_enable(void)
ssp_put_byte(FLASH_WRITE_ENABLE_OPCODE);
ssp_enable();
ssp_wait_busy_bit();
ssp_disable();
}static void flash_write_disable(void)
ssp_put_byte(FLASH_WRITE_DISABLE_OPCODE);
ssp_enable();
ssp_disable();
}static uint8_t flash_read_status_reg(void)
uint8_t buffer[2] = {0x00, 0x00};
ssp_put_byte(FLASH_READ_STATUS_REG_OPCODE);
ssp_put_byte(0xff);
ssp_enable();
ssp_get_data(buffer, 2);
ssp_disable();
return buffer[1];
}static void flash_write_status_reg(uint8_t status)
ssp_put_byte(FLASH_WRITE_STATUS_REG_OPCODE);
ssp_put_byte(status);
ssp_enable();
ssp_disable();
}static void flash_start_protection(void)
uint32_t flash_id;
uint8_t flash_status;
flash_id = flash_init();
flash_status = flash_read_status_reg();
flash_status &= 0x83;if((flash_id & 0xFF) == 0x85) { //PUYA
flash_status |= 0x2C; // protect lower 256K for Q40H Q20H D21H
else { //XTX
flash_status |= 0x0C; // protect lower 256K for XT25F02D
flash_write_enable();
flash_write_status_reg(flash_status);
flash_write_disable();
while(flash_read_status_reg()&0x03) {
//delay
co_delay_100us(20);
printf("flash_start_protection *************\r\n ");
static void flash_clear_protection(void)
uint8_t status;
//status &= 0x83;
flash_write_status_reg(0);
ssp_clear_rx_fifo();
//delay
co_delay_100us(20);
printf("flash_clear_protection *************\r\n ");
